Stihl 461 carb problems
sidis8
3:08 PM
Nj
Good morning everyone,
New to the forum here. Learning a lot, bunch of great stuff on here.
So here's my problem. Got a 461 that was rebuilt recently. Everything was running fine , no problems at all.
So I go to start it yesterday and it won't run. Full choke and half choke is fine but it wont stay running.
I tuned it a couple weeks ago with a tach, around 2800 idle and 13500 full load.
So I check a few things last night, compression good at 160 ish, vac and pressure good also. Spark plug looks good.
The only thing I changed was get some new gas from the fuel station down the street.
Do you guys think it might be a ethanol issue ? I put the same gas in a 201t I have and she runs fine.
Thanks for any help in advance.
3:08 PM
Welcome to the forum. :cheers:
Could be related to the LA adjustment?
I would go back to a 1 and 1 preset and try tuning it again. If you still have no luck, try a different carb that you know is good.
Plenty of members in NJ.
@angelo c
@LoneWolf
Lone Wolf
3:08 PM
Nj
So you tested the vac and pressure and it passed right?
Like the above poster said go to 1 turn out on both jets and see what happens.
Fuel filter on?
Is fuel line cracked?
Next try cleaning carb out with spray cleaner don't blow high pressure air in it!
Next if that fails replace carb with OEM one otherwise you wont know whats failing the new carb or other parts.
sidis8
3:08 PM
Nj
Welcome to the forum. :beer:
@angeloc
@LoneWolf
I reset the carb to 1 on each. Still has no luck last night. Gonna try a new carb tonight after work. Messed around with the la screw too.
sidis8
3:08 PM
Nj
Fuel filter on?
Yh, pressure held at 8 and same on vac.
Fuel filter is on and I pressure and vac tested the fuel line too, passed with no problem.
Deff gonna put in a carb that works in there, just gotta make it through the work day lol.
Thank you
Lone Wolf
3:08 PM
Nj
Thank you
Clean the one you have first.
sidis8
3:08 PM
Nj
So I messed around with the carb when I got home, nothing made it work.
Put in a new walbro and she fired right up, no problem.
Anybody have any ideas as why the other carb would fail like that ? It was brand new when rebuilt.
Lone Wolf
3:08 PM
Nj
Blew high pressure air in it and damaged a valve?
Cracker Boy
Fl cracker
3:08 PM
Florida
Ethonal is not good on small engines.my rebuild success has dropped on carbs since intrduction of ethonal.try to find non ethonal if at all poss.on my boat i used to have the worst problem with ethonal.what it does is draw moisture from the air it will actually etch.
Lone Wolf
3:08 PM
Nj
I must have 40 bad carbs in a cardboard box.
sidis8
3:08 PM
Nj
I think I'm gonna stop by the small local airport and see if I can get some of that ethanol free gas.
Cracker Boy
Fl cracker
3:08 PM
Florida
Ask if they have 100 low lead thats what i run its bad azz it will clean your saws out.they will smoke and lead is a lubricant
Lone Wolf
3:08 PM
Nj
I didn't use any high pressure air on it.
Is there a good way to test the carb ?
Pressure test at the fuel pipe may show a leak, otherwise the real test is on the saw. H and L jets could be bent or mushroomed also. You could have put a part in wrong also go back and re check. Sometimes you just cant fix them because the problem is hidden in an inside passageway.
