- 10:39 PM
- Dec 29, 2015
- Ontario, Canada
So basically it all depends on the finished location and shape of the exhaust port. It's mostly about maintaining piston stability and not allowing Freeport. Makes sense now. Thanks.Run the piston to exact TDC mark the piston at the bottom of the exhaust port.(I use a scribe) then when you pull the jug you can measure from the line you scribed to the bottom of the piston skirt, and that is the max amount you will be able to drop the jug without free porting
I guess if you end up with to much compression you can adjust it with your base gasket thickness, right?
