stihl 066 porting
jmssaws
Banneded
5:19 PM
So if you have a certain set of numbers you want to use on the jug do you have to degree it first and then cut the squish and base?
I rarely check the timing on a stock cylinder. I'll check the squish and cut it for the compression I want and set port timing.
6:19 PM
@jmssaws My big question is how do you know how much you need to cut from the squish and base? Is this just something that comes with experience on a certain model or is there a science behind it?
A bit of both Mike.
How much you can take max out of the band is determined by where your piston will Freeport and how much support the piston skirts have. Then you figure out base squish and base compression, then estimate what your comp will be with X out on other builds. You also wanna consider where your exhaust will land, where you wanted it to land, and where your intake will land when you cut the base.
I know that's clear as mud. I did my best.
Red97
6:19 PM
MI
6:19 PM
I'll need some more.......large ones please, 20 will work and please pm me with the total including shipping
Thank you Sir !!
I love these large deflectors !!
Red's defectors are great.
@Red97 is there anyway you can tool up an "in between size"?
I find my self wanting your larger deflector, but not being able to fit it on smaller saws.
Deets066
AKA Deetsey
6:19 PM
Run the piston to exact TDC mark the piston at the bottom of the exhaust port.(I use a scribe) then when you pull the jug you can measure from the line you scribed to the bottom of the piston skirt, and that is the max amount you will be able to drop the jug without free porting
Red97
6:19 PM
MI
Front to back dimension is to deep?
Same size without the ramp leading up to the opening?
