Stihl 064/066/288 Saw Build
jmssaws
Banneded
8:14 PM
The saws I do will be faster somewhere below max tune unless it's a very short cut. I think most saws are that way
Brewz
11:14 AM
Hunter Valley - Australia
Only time a richer tune would be faster is in a very long cut.
If you have two saws with the same exact power but one makes it 1k faster then it will clobber the other,that's what we are doing with porting,we're making more power but we're also if doing it correctly making that power at a higher rpm.
I hear the word tourqe a lot but tourqe Is a useless number honestly for a 2 stroke.
Hp is king of them,we're trying to gain chain speed and the only way to make a saw faster is to turn the chain faster.
I have a 056 mag11 sitting here and there "tourqe" saws but there also not very fast because they lack rpm,the 2100 sitting here is real strong but it's not fast even with a long bar they are behind these 064's and 066's. Hp is the combination of tourqe and rpm and that's what makes fast saws.
I hilighted the bit that trips most of us novice part timers up :-)
I love my 2100. It tunes out to almost 13K and tries to drag you into the log, but like you said, its not faster in the cut.
The Stihl 076 I have built...... 111cc with 180 psi. Lots of grunt but it doesn't cut faster.
I cant see myself selling the 2100 though.... I start it just to hear it idle and it will be great on the mill
jmssaws
Banneded
8:14 PM
I hilighted the bit that trips most of us novice part timers up :)
This 2100 sounds like my 5200 but bigger
Brewz
11:14 AM
The 2100 is the best saw I have ever heard at idle.
I am yet to really stretch its legs with a 42" bar but I recon it will do it well
t4driller
Daddy Day Care
9:14 PM
Southwest pa
All very good info on tuning. The 350 I did with 359 carb has a wonky idle. Wants to stall right after a long cut, but will idle good after 30 seconds or so. I'll try and get it tuned in better.
jmssaws
Banneded
8:14 PM
Probably just a touch fat
CR500
9:14 PM
Western NY
I always feel better when the person I'm building a saw for knows how to tune,I can tell a lot about how they keep one tuned and the condition of the saw just by checking where the low and high are.
I don't have to start to see what's up i just check how far out both sides are.
I know I suck at it J lol..... I'm still trying to learn
Gun32gtr
11:14 AM
Australia
First time poster. I've bought this saw of brewz and after reading all this it's awesome to know how much research he did when building it. I've got couple other saws that will be getting some treatment off brewz very soon.. 44 46 and 64 are the 3 id like done over the next 12 months.. standards saws are boring as hell
K-techcowboy
OPE Member
8:14 PM
Oklahoma
When you start porting the hell out of one you loose the ability to hold a good tune,especially at idle.
It helps me to not use the la,it just changes the low setting so I never use it. You will need to tune them right on the edge of lean,i rarely have a 066 tune over 1 and 1.
If your low is more than 1 turn out then the la is turned in to much. Back it out till it ain't touching then set the low.
I've never seen donny have idle issues after porting a saw. I've never had issues either. Theres too many variables to put if off on the thing. The only saw i had trouble tuning just simply needed a bigger carb. Boom done runs straight alcohol and revs over 18k
9:14 PM
I’ve learned something as simple as a worn clutch can make it a lot more difficult to set a good tune on the L jet.
