Stihl 051 chain recommendation
WillG
11:16 PM
Norwich CT
Setting up my 051 with a 36" Tsumura bar. I cut a mix of hard and soft woods that are sometimes a little bit dirty from being on the ground. What would you guys recommend? Full skip or full comp? The 051 is 89cc and it's setup with a .404 7 tooth spur sprocket. The bar is .063 gauge.
11:16 PM
It will cut better with 3/8 most likely, but I’m sure a old torque saw like that would pull .404
WillG
11:16 PM
Norwich CT
Thanks Mason. However 051 stuff is getting hard to find. I did a bunch of looking on eBay for a 3/8 setup for it and didn't have much luck as mine is an early one and the oil pump drive components are a bit weird.
Junk Meister
10:16 PM
Nebraska
3/8 with 8T rim cuts netter than my .404 with 7T rim wearing a 24" bar went to roller nose on the 3/8" cuz of chain speed (pricey) Oregon drum on the older oil pump
WillG
11:16 PM
Norwich CT
On mine I have the pin drive oil pump drive. Took me forever to find the right drive worm gear and drive plate since it was all broken when I got it. I've been searching for 3/8 stuff for it with no luck.
Carhartt
11:16 PM
Central Pa
Mine pulls .404 7T just fine full comp with 30 degree grind. Ive never cut a big softwood but I bet that would be fun to watch the chips grow.
I am sure you can search 050, 051, 075, 076 etc. Wonder if Oregon makes a rim sprocket for it?
So I looked it up they do. Part # 22271x (power mate system) 22273 just the rim. Or OEM 1111 640 2026.
WillG
11:16 PM
Norwich CT
They used to. The ones on eBay don't have the correct oil pump drive configuration. And anyways she was pulling a 21" with .404 .063 RM full comp in red oak with a 7T sprocket just fine. Just ordered the bar last night.
Junk Meister
10:16 PM
Nebraska
You may wish to verify.. The Oregon I bought looked (To Me) to fit either one of the oil pumps or square/rectangular tangs, that go 9 oclock to 3 oclock. Just drove out the pins in the spacer plate but don't remember all the details at the moment. I am thinking there is a pump drive that has a slot off center so I reserve being sure until some one more familiar experience jumps in. If you swap tips to the new bar it would run 3/8" fine My 051 really wakes up when you compare the saw using 3/8" 8 Tooth rim to the 7 Tooth .404 both with 24' bars but the .404 is a hard nose bar.
WillG
11:16 PM
Norwich CT
I don't remember what it used for the drive. I don't feel like taking it apart again. I'm just going to run the .404 .063 semi chisel full comp Oregon chain and see how it does.
Lightning Performance
11:16 PM
East of Philly
How much was shipping?
Ryan Browne
10:16 PM
Wisconsin
Semi chisel .404 seems like a great setup for dirty wood. Plus, you guys, he has a nice running 346, so if he needs a saw that cuts fast, he can use that one!
Full comp will be smoother. Full skip will have a lot less cutters to mess with when sharpening.
WillG
11:16 PM
Norwich CT
Plus the saw would have originally setup for .404. Thanks man the 346 is a little rocket! I also have a nice running 034 that does excellent too. I'm also on the hunt for a 60ish cc Husky to build/mod like the 346.
Carhartt
11:16 PM
Central Pa
I looked at mine last eve and it has a rim sprocket on it. So I assume it wld be a quick change over to .375. Now I have to remember to look on sprocket shelf to see if I have another.
Jungleman
11:16 PM
Maryland
Dang. I just went looking for that bar to buy it and it’s gone. Guess I was too slow.
11:16 PM
I would go with skip on a bar that size with .404. Full comp is probably a bit much for that saw to pull with .404 36” in hardwood.
