Stihl 039 intake port
Hobbylogger
11:20 PM
SE Ohio
86EB1412-6FB1-4078-A459-FD5A965CF8FE.jpeg FDB18F62-4A69-451D-84AA-662AA09C26A4.jpeg 0012DCC2-6C8E-4775-B3E1-E95F8D24ECEB.jpeg I just got this upper end for an 029 build and I noticed this casting/ coating blem on the bottem side of the intake port. Should I remove and chamfer it? Also I noticed the transfers have sharp edges, should I chamfer those? Any input will be greatly appreciated.
Lightning Performance
11:20 PM
East of Philly
View attachment 300253 View attachment 300254 View attachment 300255 I just got this upper end for an 029 build and I noticed this casting/ coating blem on the bottem side of the intake port. Should I remove and chamfer it? Also I noticed the transfers have sharp edges, should I chamfer those? Any input will be greatly appreciated.
Best to check the intake timing first. It might need filled in after proper prep.
Sharp edges on the intake port window mean nothing if they never touch the rings. Same at the transfers. Tinny bevels are best. Crumbs might come loose so best to remove them. If it is plated it won't move most times unless you have a big booger hanging out.
Hobbylogger
11:20 PM
SE Ohio
It’s smooth on the inside along the cylinder wall, it’s like a casting bleb that got milled and plated. I’m going to check the timing once the piston arrives…. Thanks.
11:20 PM
East of Philly
You need to see some of the intakes on the new 462. Your not wrong
Hobbylogger
11:20 PM
SE Ohio
This is a a trial for me, my first time attempting to port or modify a saw.
11:20 PM
East of Philly
Well if you wreck an intake just fill it in and start over. If you wreck the exhaust by width you roached it.
The rest you got some wiggle room so start ruining pistons to get started. Just buy a box of four and get on with it. Your not cutting the base or band so it got real simple for you. Go find your numbers first. Then decide where to go with it.
Hobbylogger
11:20 PM
SE Ohio
Thanks, that sounds like a great plan. I’m a little meticulous about these things but not afraid to mess up; as long as I know I messed up… lol
