Stihl 036 Carb options
paragonbuilder
3:38 PM
Norwich, CT
How does it feel compared to your 036?
mdavlee
Hillbilly grinder
3:38 PM
TN
He measures his finger ports for width and depth.
I just put the good eye on em' o_O
I lack patients
Yeah I don't spend much time making my stuff pretty. I tear them back apart and polish later if I plan to sell. I hate to spend an hour on making them slick to go back and grind away on them.
Backtroller
2:38 PM
Land of Badgers
Because Al is a perfectionist! Have you ever seen close up pics of his work? It's some of the nicest that you'll see
He sure does awesome work. I have photos on my phone to show my buddies what has been done to my saw after they run it. One has a new MS362 that was thoroughly embarrassed by Al's handi work. Too bad you can't see his work from the outside. I'm still waiting for a sticker though.
3:38 PM
We will run both on Friday. Two things I didn't do, clip the lower transfer lip and add bridges. This jug came one at an 84-85 intake as opposed to 82 on my other 036 and Backtrollers. I didn't want to reduce case volume any further.
If is slower, I may pull the jug. I'm at the point where I can't tell what's fast anymore. The video was terrible above. I was using a lot of energy making sure I didn't cut my Johnson off. There was side loading, diagonal cuts, etc...
I can't even tell what's fast anymore. It looks like it made it through that 16" log in about 5 seconds. I guess that's ok.
How do you cut the transfers on an angle like that? And make them equal.
David,
I spent some time really studying the factory opening in the transfers. I put a ring in at the intake opening point and measured the distance from it to the exhaust opening point. I duplicated the opening angle. My other 036's runs well at 120, and this exhaust came in more like 102ish, so I went with 118-122. I just looked at my notes and it was 118, not 117.
I put a ring in and marked at 122, then again at 118. I carved a diagonal line between the two on both sides.
All that extra work may have not done a thing. The 038 boot can be playing a role with torque, I'm not sure. It's a variable I changed but really shouldn't for testing. I wanted to copy and blend into the factory floor the way they cast it. The only way to do so was to copy their angle.
Again, I wanted to try something new. It may have not added a thing.
Backtroller
2:38 PM
Land of Badgers
I don't want to leave any stone unturned. I ordered a 038 boot for mine. If it comes before Friday I'll test it out before the weekend.
3:38 PM
I bet it slows you down Pat. The more I think about it.
Your jug was a great one with a higher intake. Come to think of it, my badass 036 has an 84 intake just like this one.
A smaller opening would cause less flow, but more velocity, and less blowback. It may be the very reason this model does OK with a low intake.
Would be interesting to see your results Pat. I put some Dirko around the boot. The outer diameter of it is slightly larger than the 036 boot.
May sure you don't get an air leak.
I think epoxying the intake floor may work really well with the larger boot.
David Young
Safety First !!!!!!
3:38 PM
vt
Al I agree with your hunch, if you have a bigger tract you need to give it less time. If the carb and boot are smaller you will need more duration to make it fill the base.
To get a nice low idle and easy starting it always seemed that a low intake duration helps. I assume it is good case compression that helps fill the jug at low speed. also lower fuel consumption
ill be interested to see how it turns out.
Backtroller
2:38 PM
Land of Badgers
Man, now I'm having second thoughts about monkeying with it. It runs so good now I'm not sure I want to play with it.
