Stihl 029 super to 039 conversion
5:37 AM
Oh and I you want some fun kkemp look up Icepick69 in the chains are I got some stihl rs .325 square ground from him for 27 a loop its fun stuff
kkemp
6:37 AM
indiana
Sounds like fun I may have to try it .
5:37 AM
I forgot to add locally same chain is 25 round ground
fearofpavement
6:37 AM
Georgia
. That's what I heard . I'm going to try to use the one on the saw it looks good . I'll inspect it first though .
I've also had problems with non OEM fuel lines on this series saw. I usually reuse the original if it's still pliable. I've rarely encountered bad ones. (well, not rare, but not a common problem)
Mark71gtx
6:37 AM
Fuquay Varina, NC
For some reason Stihl likes to run their fuel lines like a curvy dirt road. The aftermarket lines tend to kink when making all of those twists and turns. I built several 026's and 029/039's with the supplied aftermarket fuel lines. Every one of them came back. All OEM on a Stihl from now on. It makes life so much better...
6:37 AM
Plus 1 on oem lines the chinese ones I've used are kind of pressed or vulcanized together and they split at the seams haven't had to change many oem you'll know if it's bad usually it will be hard to start but wont stay running.
5:37 AM
Nice I just went out this am to put one back together and realised i forgot crank bearing :facepalm:
kkemp
6:37 AM
indiana
That's dissapointing when that happens . Lol . . Hopefully my stuff will be here tomorrow .
kkemp
6:37 AM
indiana
20161228_150818.jpg 20161228_150751.jpg piston and cylinder came today . Not sure on the quality though
5:37 AM
1127 series are open port unless you got some prototype and the port bevels look ok from what I can see how do they feel because thats about the most important thing on these motors.
kkemp
6:37 AM
indiana
The bevel feels good to me .
