thompsoncustom
Wanting Stihl PS Picco chain or any non safety chain 60dl .050 doesn't matter if it's filed or ground just needs to be square looking for a fast work chain for clean wood. Thanks
I don't think there is you have to have someone grind it.Wish I'd known there was a square picco before I bought a couple 8ten brand square for my little saw. Full width tooth does have it running slowish.
Stihl says their PS3 is square.I don't think there is you have to have someone grind it.
it's not, ps3 is just PS with added safety rakers. PS is good chain but not square even tho stihls website does say "square cornered cutter"Stihl says their PS3 is square.
Looks like a square tooth that's round filed/ ground.It isn't.
A.k.a. Full chiselLooks like a square tooth that's round filed/ ground.
yup that's what I need just square ground
I'm going to buy this PS3 chain to get the narrower tooth. It'll be square ground after a few sharpenings with a double bevel file.yup that's what I need just square ground
The tooth isn't exactly the same?I'm going to buy this PS3 chain to get the narrower tooth. It'll be square ground after a few sharpenings with a double bevel file.
Maybe the safety chain gizmos can be removed too.
There is the new light bar with .325 RSP that comes on the newer 261’s. Might be your ticket. I’m told that they stay sharp longer than regular RS.This is for that saw you did the cylinder work on, Runs amazing BTW. If it's under 16in (bar length) this is the saw I prefer to use due to the power to weight ratio it has. The Picco bar help drop some weight and the narrow kerf cuts super fast with the stihl PS chain. Was just looking to play around with square chain as it's something I haven't done before.
That RSP some fast stuff,There is the new light bar with .325 RSP that comes on the newer 261’s. Might be your ticket. I’m told that they stay sharp longer than regular RS.
I personally like a 16” 3/8 on a good 026. Should pull it without an issue. You can go square on that and hold an edge longer than round Picco.
