Spinning and breaking 1/2 pitch chain
WillG
6:58 PM
Norwich CT
I'm in the process of buying some 1/2 pitch chipper chain on fleabay and what do I need to break and spin it? It is coming with a few presets and ties. Can it be done with a .404 spinner?
jakethesnake
I Am The Snake
6:58 PM
Here & Now
I’d probably use a punch and ball peen hammer. That’s how I break my chain and spin it. Even .325. The heavier chassis of the 1/2 would be easier to deal with. .404 is easier than 3/8 for example Plus the rivits are larger so it leaves more meat to flatten a new Rivit without needing presets.
WillG
6:58 PM
Norwich CT
Did score this last night. Exactly the number of links I need. Just need to spin the rivets. I'll call my local saw shop.
beaglebriar
The Peanut Gallery
6:58 PM
Warren Center, PA
Pretty sure I have a roll of that in the shed.
Philbert
Chainsaw Enthusiast
5:58 PM
East Dakota
Oregon sells their standard duty spinner and Breaker, and their heavy duty ('DuraMax') set which also works with 3/4" pitch harvester chain. Some older hand held saws also used these larger pitch chains.
I doubt that it would be worthwhile buying this heavy duty set for 1 or 2 loops.
Breaking the chain with a lighter duty breaker could damage the tool: I would grind the river bead off first. Spinning could also be difficult, but the rivets can be peened over.
Or, find someone with the HD tools.
Philbert
WillG
6:58 PM
Norwich CT
Oregon sells their standard duty spinner and Breaker, and their heavy duty ('Duramax') set which also works with 3/4" pitch harvester chain. Some older hand held saws also used these larger pitch chains.
Philbert
I'm going to get together with @SOS Ridgerider soon and we're going to get the 2 rivets spun and peened over if needed.
WillG
6:58 PM
Norwich CT
Got together with @SOS Ridgerider today and his Harbor Freight spinner breaker worked perfectly for the 1/2 pitch rivets. A little bit of touch up with a 1/4" file and some adjustments to the carburetor had it running and cutting well. Slow and loud but gets the job done!
