Spark plug
Genius
First member of ASlite to receive a infraction
10:47 PM
Uncle Willys basement
Why Bosch only
Price primarily, I don't have a source for NGK, otherwise I'd run those too.
In the past I have had two champion plugs fail. One saw I ended up putting a new coil in because I wasn't getting spark, put a new coil in and nothing. I put a new plug in and all was good. I had it a second time where the plug wasn't firing, put a new one in and all was good again.
10:47 PM
I run Bosch, but would also run NGK. Had a bad experience with Champion years ago, so I just avoid them.
Eccentric
Yes, we do have trees in Wyoming.
8:47 PM
Northwestern Wyoming
Been running NGK for years. Seen friends have some issues with them......and I had a dud right out of the box recently. Going to switch over to Bosch. Have seen several Champion failures over the years. ND (Denso) are great plugs. Always have had good luck with them in motorcycles. If I can get a good price on them I'll run those.
CR888
2:47 PM
Australia
Since german bosch dried up (stashed a box), l use Denzo (japan) but having said that I got some champion plugs cheap on close out sale and they have been really good. I don't have plug troubles really, often a plug lasts 50+ hrs and still look good. No longer clean them with wire brush but instead just a old toothbrush, carb cleaner and dry.
wildroamer
Winning!
10:47 PM
Vermont
Generally use ngk because they're readily available. Haven't intentionally avoided Champion, but will from now on thanks to this thread.
Jughead
10:47 PM
Ngk only for me.won't touch a Bosch since theyre made in china.i've always hated champion.they always left me stranded in the woods when riding my bike back in the day.
