SOLO Solo thread
Partner
2:41 AM
Poland
Ray is irreplaceable :-) This is the second time he is helping me
Partner
2:41 AM
Poland
for good morning, there are no screws in the H&L carburetor / Mike gives the tillotson carburettor and the wolbro ws12 forum is trying to get to him
Partner
2:41 AM
Poland
ok, I got to the carburetor and I got out with Walbro WS2, does anyone know if the H&L screws fit with another WS?
Partner
2:41 AM
Poland
Ok, I stole the screws from ws10 ;-) I flew the fuel line and if there is a spark, I will try to fire it
Partner
2:41 AM
Poland
the saw works but only in emergency mode with a fully closed throttle and the L screw in the gas tube unscrewed / air leakage / sealants are metric? solo 650av
Partner
2:41 AM
Poland
solo 620av has the letter U on the cylinder by the spark plug and solo 650av has the letters CI / who should check
Partner
2:41 AM
Poland
sealants are good / broken there was a carburetor mounting thread on one screw now works well I have to reduce the chain and see if the oil is running
Partner
2:41 AM
Poland
The sealant on the flywheel side has dimensions 25x15x5 mm
Partner
2:41 AM
Poland
The guide was hanging on the wall for over 10 years, someone drank the middle 12mm and I drilled the oil hole right through and it fits well. The tuple is but for the tests it will have to be enough for now. I unscrewed the spur
Partner
2:41 AM
Poland
How to clean the air filter in solo 650av is it felt?
Partner
2:41 AM
Poland
I have 0.35mm on the ignition interrupter, is it acceptable in this model?
Partner
2:41 AM
Poland
thread the two holes in the M5 mm flywheel and do not pull too hard and simultaneously tap the short fan fins on both sides with a soft hammer
Partner
2:41 AM
Poland
