wildroamer
Winning!
- 7:02 AM
- Jan 5, 2016
- Vermont
Thanks you two, will do.
Put a gasket in it and put that mofo together and run her!Thanks you two, will do.
Patience grasshopper!That's a 30 minute job! Why is it takin so long???!? The suspense is killin me...
OK, starting to put the puzzle back together. I know this is a crap pic, but I'm wondering about the throttle cable there. Just to the right of it is a black cylindrical piece with a slit in it. It doesn't seem like it, but am curious if that cable is somehow meant to go through that slit first, before connecting up top?
Gawd I hope so! 3-6 months from 2/14 allows for touching toe to floor, not walking. Yikes, might be piss-revving only!So,are you going to be healed up enough by fall to use this thing?
Hint for the 7900 owners... clip the solo cylinder to handle spring shorter and run the threaded screw plate in a little further. Then the springs will be the same height. As you can see Solo specified a larger coil spring for that AV so it wont stretch as much as the thinner dolmar /makita 7900/7910/6400/6401.View attachment 13728
FYI, those of you considering the 7900 spring kit for the 681.... Don't bother. Only one of them is a direct swap, the right front bottom one. Right rear is wrong size, as is the one for the wrap. As for the two on the clutch side, I see no way to remove the spring from the cap in order to get the old screw into the new spring.
Ha ha I'd look that guy up if I needed an undertaker.I am curious. SO want to fire it up! And I would send it to you, honest, it's just that your avatar doesn't look trustworthy!
