- 4:59 AM
- Dec 3, 2015
- Banner Springs Tennessee
Mind if post up some numbers with ya?
Hell no......please do. Let's get this thread started rockin.
The 7910 jug just works better on this chassis than the 681 jug....
OK, so you like the 7910 jug on the 681 better than the 681 jug.
But why is the 681 chassis better than a 7910 chassis???
Have you tried even higher yet?I've not checked the compression........my gauge says everything is blowing about 200psi. I don't trust it much these days.
I'll share my theory. Remember......it's just a idea of mine.
From the squish band down to the roof on the exhaust port is about 25mm. I see this a lot in really strong saws.
If you set this saw up at 102° or so it's way lower than that. So, I started thinking that the "power stroke" was actually too long in this case. So......I started at 98° then 97°......then 96°. I also raised the transfers as I went up. Now.....the intake floor is at 81°. That's a little too low on many saws.......but this saw has a really tight case. So......with a 81° intake, I felt like I could take all the other numbers higher to match it. Does this make any sense?
These saws, if set up properly can still run good with insanely high exhausts.
Send me one..If it gets any stronger I'd be surprised as hell. I think that it would start going backward.
The unlimited saw advanced 35°past stock is holding 12,400 - 12,600 in the cut in that same wood.
So if length of stroke dictates exhaust height to an extent, I wonder how an 064 would run with 180 degrees of duration????
Send me one..
I wanna run it in the 5 cube at the Linn races..
I bet it would do well..
I believe July. Muffler saws on gas.I'm waiting on a brake handle to put mine together.....when is the event?
Mean work saw and good chain will get the job done I think.
