So what did you buy today
Chainmale
1:10 PM
Tasman New Zealand
Partner
3:10 AM
Poland
[CYTAT="farminkarman, stanowisko: 1393250, członek: 13535"]Wkrótce przez nie przejdę i zobaczę, co mam. Jeśli znajdę, zrobię ci PW[/QUOTE]
it was a joke :-) the shipping would have eaten it, but thanks for the good wishes
Partner
3:10 AM
Poland
Mini zgrzewarka punktowa pojawiła się dzisiaj, aby zgrzewać paski podczas przebudowy i napraw akumulatorów.
[DOŁĄCZ]346900[/DOŁĄCZ]
Jest wielkości zewnętrznej baterii 10k mAh i może służyć jako zewnętrzna bateria 5,5k mAh.
how does working time work?
3:10 AM
I haven't tied it yet, battery was flat so I had to charge it.
According to YouTube reviews this unit can make many dozens of spot welds per battery charge and doesn't overheat.
I will try remember to report back once I give it a try! :)
3:10 AM
0.15mm steel strip (not nickel) , fried straight through on "Gear 6" , "Gear 4" was less destructive yet created a firm bond.
"Gear" is the current intensity level, higher gear = more current.
Gears 1 through 9 are available.
I am impressed, this comes out of a 3.7Volt Lithium Polymer battery.
P.S./Edit:
I tore the gear 4 weld apart exerting a lot of force, but the gear 6 weld will not budge.
No tools used, just pulling the strip noose apart with two hands/fingers.
Good weld!
