So what did you buy today
whitesnake
1:52 PM
NY
Bought a couple pair of new boots off Craigslist, got home and the wanted to try on one, well he ended up wearing them the rest of the night and he likes them. Can't wait till this 14yr olds feet are 10.5 instead of 10's lol.
Also bought an ms311 that was supposedly overheated from a dull chain per the dealer, I haven't looked at it much.
Then bought a 60 gallon Craftsman air compressor. I pulled the compressor so it would fit in the car as we were an hr and 10 min from the house, had a 1/4" to spare :D.
View attachment 339033 View attachment 339034
Before we picked up the compressor I stopped at a gas station to check and see what had been listed since we left the house and saw this o_O. I offered to put her spare on but she refused. If you look close you can see the plug in the sidewall :eek:. She put 2 cans of fix a flat in while I was there and used the air 3 times and the level never changed.
I sat there until she was done to see if she'd change her mind, not once did she even look my way, whatever lol.
Nice I like it! Tank looks in great shape! Is that in a Camry? Looks like something I would do lol. Hey fuel isn’t getting any cheaper gotta do what you gotta do!
whitesnake
1:52 PM
NY
Sent from Hoskey Hills
Man them some diggers! Only way to go. I’m actually gonna be ordering some bar tires for the rear of my zero turn. They’re aged anyway but sick of spinning and sliding around. Seems you do less damage with a more aggressive tire cause you actually have traction. As long as you use a hair of caution that is.
7:52 PM
I purchased beer and ice cream cones after work.
I know, nothing special.
But I also found this Li-Ion battery pack in the battery recycling bin at the supermarket.
There is a good chance that one or more cells are still useable, those that aren't will go back into that bin.
This pack should contain 4 cylindrical 18650 Li-Ion cells, each 3.7Volt/2200mAh
IMG_20220611_155302.jpg IMG_20220611_155320.jpg IMG_20220611_155324.jpg IMG_20220611_155347.jpg
Ronie
1:52 PM
NC
7:52 PM
Good find
I think so too.
I do not have a corresponding device nor charger to check whether the pack is bad or not, as auch I will most likely just salvage any cells that are not dead or dying.
I do have a charger for cylindrical Li-Ion cells, and I use 18650 cells in a LED head light. :)
nbbt
12:52 PM
5543X, 5644X
View attachment 339950 View attachment 339951 View attachment 339952 View attachment 339953
I've done product development adding Li-Ion/Polymer to UL listed devices.
One of the easiest ways to get cells back is to do an induvial cell charging using a charger that has a pre-conditioning circuit. Note if induvial cells read under 1.5VDC there is (MOST) likely cell damage all ready. Recommend to recharge when voltage gets to 2.7VDC
I have used this TI eval kit for development (https://www.digikey.com/en/products/detail/texas-instruments/BQ24113EVM/679856 ) and to rejuvenate several laptop battery packs to at least partial capacity.
Reading through the eval kit instructions. You will get some good ideas for this.
Good luck with your experiment.
KS Plainsman
12:52 PM
Nothing major, but something I've wanted for awhile, an ultrasonic cleaner. Just a little half gallon unit. Used it to clean a carb and it worked great. Now I'm looking at getting a bigger one.
7:52 PM
One of the easiest ways to get cells back is to do an induvial cell charging using a charger that has a pre-conditioning circuit. Note if induvial cells read under 1.5VDC there is likely cell damage all ready.
I have a Nitecore charger which records charge time, knowing the max charge current it is easy math figuring out "dying" cells.
I already have a dozen 18650 cells salvaged from defective laptop battery packs, as such I am used to tinker with Li-Ion cells.
Quality cells with good built in undercharge circuitry will show 0Volt once they bottom out too much.
I experienced some of auch cells to revive to full capacity.
The issue with battery PACKS is that one defective cell can and will take out neighboring cells over time, that is why a defective pack should be inspected as soon as possible to identify and remove dead cells.
