So what did you buy today
Partner
12:43 PM
Poland
A few items for $25, red Knipex, 2 pcs. Weller soldering iron and Russian precision caliper 😉 interesting mt2 sleeve for a 10mm cylindrical drill. Orange voltage tester for an electrician, I haven't seen one like that
Partner
12:43 PM
Poland
A steel shaft and a spring, I don't know what it is for and why is there a sheet of metal in the hole of the electrical terminal? Or such long Mig Mag tips, 1/4" thick, for a 1 mm wire and a length of 55 mm without thread
SimonHS
11:43 AM
Yorkshire, England
A steel shaft and a spring, I don't know what it is for and why is there a sheet of metal in the hole of the electrical terminal? Or such long Mig Mag tips, 1/4 thick, for a 1 mm wire and a length of 55 mm
Sheet metal punch? The one in the photo below has teeth to help it cut. You drill a small hole in the sheet, pass the bolt through the hole, screw the punch on and then tighten it with a spanner. The disc with a hole in it is the waste piece of sheet.
Partner
12:43 PM
Poland
The outer sleeve is made of spring steel and has approximately 5 turns
whitesnake
6:43 AM
NY
Somewhat local advanced auto closing made a run today says I saved about $1200 lol. $137 for all of thisView attachment 444002
Wow. I’ve heard this from a couple people now. I shall check my local advances. Seems like everyone in my area has been using Autozone and Napa mostly for the last several years.
