Small sawz, what's muh options?
Johnmn
6:01 PM
Minnesota
Dolmar 421 enough said! Honestly the best small saw I have run. It's lightish, good power, carb holds a tune great, good av and filtration. Set it up with 3/8 lp and go to work! Oh and get rid of the cat and retune
Simondo
12:01 AM
UK
I have zero Dolmar dealers around here that keep anything in stock. Are these clamshells? I dont have any IPL's for Dolmar.
I looked on their website and it looks like they are about a pound heavier. I know after adding a bar, chain, oil and gas it'll be closer to 13-14#...
I love Echo, for buying a new saw I would prefer buying Echo over anything else. But from what I see everything Echo has to offer in the small CC range is a clamshell.
To heavy. I had one and I am afraid its a little to much for him.
Real world figure ...Ps 420 (your 421) power head with 15" .050 bar and chain out of the box . They drop to just over 12 lb on a 14" Lo pro bar and chain.
blsnelling
Friend of the Riff Raff
7:01 PM
Franklin, OH
Fill it with fuel and oil. I have some additional weights, but they're with fuel and oil, ready to cut.
Simondo
12:01 AM
UK
The point of me posting the "real world weight " was to show what the powerhead and bar in standard form was . You can fill the tanks to whatever you want ..full ..1/2 full .... but other than a bar and chain swap thats the start point of the saw. I also take into account the lightening load when using the saw as it uses its oil/fuel .
Simondo
12:01 AM
UK
I simply asked so that we could compare weights of some additional saws.
Back in a bit. I will put up a weight of a saw with a 14" sugi bar and lo pro chain up as iv one set in that form and then il change it to the standard bar that comes in the box.
6:01 PM
Would I be crazy for suggesting battery powered? 5.29 lbs before battery and cutting equipment for the husqvarna version.
I would say your not out of line. And there was a section like this a while back. Not sure what be came of it.
blsnelling
7:01 PM
Franklin, OH
MS241C w/16" B&C
MS261C v.II
346XP w/16" B&C
FergusonTO35
7:01 PM
Boonesborough, KY
What about a CS-450P?
Cs-450P is a great saw but really needs to go on a diet. For pretty much the same weight and size you can get a 490/500/501. Having had both the 450 and 500, you definitely get more performance out of the latter.
If the OP is willing to consider a clamshell, the Echo CS-400 is a solid choice and doesn't weigh much. You can buy a really nice used one on Fleabay for under $200.00. I have used mine pretty hard and it keeps coming back for more. Never had a problem with the clamshell construction either, don't use your saw as a prybar or drop it out of a tree and you'll be ok. The MS241, 543, 421, 024 etc. are not exactly lightweight once you add bar, chain, fuel, and oil.
Armbru84
Just trying to get by
7:01 PM
Michigan
With the intended owner in mind and the fact an 036 is to much saw/weight, I think a super light pro saw is in order. My pick would be a Mtronic MS201 rear handle with 14"/16" Light bar running 3/8 050 Picco Super. That saw will be super light and very capable cutting <14" wood on his trails. I have one, expensive...yes but if he needs a really light non clam shell pro saw, its very hard to beat. I can use mine for hours & its so easy to use.
I happen to have a rear handle kit for a 200t...just growing that out there. And I am close to the OP.
