Simple Chain Filing Vise
IffykidMn
5:25 AM
Minnesota
If the chain is not mounted on a saw/bar, nothing beats this.
I am considering to buy a second one, but then again I reduced wood cutting to a crawl.
Yes and more is better if one has the space the money and need.
One set up for 3/8 left cutter one for 3/8 right cutter, third set up .325 does not get used as much as I don't run a lot of .325 and the fourth setup for rakers.
One of those automated chain grinders would be cool as well but the cost. $$$$$$$$$
4 grinders and yet at times I will throw a chain in the bench vice on a spare bar to do a quick hand file. :eek:
I also keep a modified stump vice mounted to a board to do quick infield sharpening as required if it makes more sense than changing chains, prime example is needing an excuse to take a 10-minute break from cutting.:risas3: or others who show up on a job site not quite as prepared. :eek:
12:25 PM
AMA Maxx grinder does left & right hand cutters (not both at once, though!), the chain vice swivels as does the grinder head.
I'd like a second grinder permanently set up just for rakers as it differs greatly compared to tooth grinding.
Switching between a 3/8" (& .404") and a .325" (& 3/8" LP) wheel is not an issue as I don't grind many chains at all.
Although, owning 3-4 AMA Maxx grinders each for a specific chain gauge would be a sweet setup! :)
Sloughfoot
3:25 AM
Norcal
We're a simple hand filing people that don't trust nor understand such things.😥
12:25 PM
I was a freehand filer for decades till I discovered the Archer FastFiler roller guides.
Those made my chains drop through oak logs.
Then I impulse purchased my pre-owned AMA Maxx grinder and it is an impressive time saver compared to filing chains.
Evolution! :thumbsup:
12:25 PM
Never saw a MAXX grinder in person, or had the opportunity to try one.
We should start a separate, grinder comparison thread.
Philbert
Blasphemy!!!
Philbert the chainsaw chain guru not having had met an AMA Maxx grinder. 😱
Whadaya doin' this weekend?
Come by and try my AMA Maxx grinder.
I may be having an extended weekend due to an holiday on Tuesday. 😊
12:25 PM
Sloughfoot
3:25 AM
Norcal
The $20 vise extenders work pretty well. Serrated and much thicker than I thought they'd be. Links are rigid all but one end and that one is more rigid than in a bar. Might be tight all the way in a better vise. Would be 5 a side at a time with full comp 3/8. Half skip in the photo
