IffykidMn
- 12:16 AM
- Aug 13, 2021
- Minnesota
Yes and more is better if one has the space the money and need.If the chain is not mounted on a saw/bar, nothing beats this.
I am considering to buy a second one, but then again I reduced wood cutting to a crawl.
One set up for 3/8 left cutter one for 3/8 right cutter, third set up .325 does not get used as much as I don't run a lot of .325 and the fourth setup for rakers.
One of those automated chain grinders would be cool as well but the cost. $$$$$$$$$
4 grinders and yet at times I will throw a chain in the bench vice on a spare bar to do a quick hand file.
I also keep a modified stump vice mounted to a board to do quick infield sharpening as required if it makes more sense than changing chains, prime example is needing an excuse to take a 10-minute break from cutting.
