Shindiawa 738sx hybrid Waffle
Red97
5:52 PM
MI
Going to waffle off this saw.
10$ per spot 85 spots total.
Already have the list going
Dub11 5 waffles.
redline4 2 waffles
Woodpecker 5 waffles
Backtroller 2 waffles
Czed 4 waffles
huskihl 5 waffles
Lauren 10 waffles
PA Dan 2
Bilge Rat 2
Please copy and paste to add your name.
Once all 85 spots are claimed, I will go back down the list allowing each to pick numbers 1-85
Then allow my 4yo to use the random number generator to select the winning number. Where he stops nobody knows.
Once all the numbers are claimed, I will collect funds. Once all the funds are in we will draw the number.
The waffle winner will receive the saw pictured above, along with the oem 600sx p/c I will pay shipping to the winner.
I will work on a post with all of the build details.
Red97
5:52 PM
MI
The build.
Brand new, factory fired 2015 Shindiawa 600sx
The cylinder 50mm white box 044 d chamber aftermarket.
Welded the sides
Turned it off
Cut squish
Red97
5:52 PM
MI
Fully ported.
.026 squish
96
116-120
82
I built this to be a quick/strong 20" bar saw. I feel it is pretty well that.
Can it pull a 36" loop? Probably, can you set the spikes and try to rip the tank off with that setup? No, i feel you will be disappointed if you expect that. Altho i have not tried yet...
73.8 cc saw in a 60cc chassis.
This saw has about 20 cuts on it, not even a full tank of fuel.
Meteor piston, caber rings.
Healthy muffler mod.
Still have to get a muffler brace on, but that will be done before shipping out.
Red97
5:52 PM
MI
Some trimming to fit under the covers.
I have built 3 just like this.
Make sure they are up to temp set the H side and it holds all day long. Once it cools down they are pig rich until warm.
Being upfront and honest. That is the only qwirk I have noticed.
Meteor piston, trimmed the skirt to get the intake.
Other than the decomp hole in the top cover, and the muffler mod this saw could easily be returned to stock if needed.
Everything other than the cylinder, piston and intake boot is all stock.
I feel this saw will pick up a good bit with a larger carb/filter fitted.
Any questions or concerns please ask before putting your name on the list.
Red97
5:52 PM
MI
Dub11 5 waffles.
redline4 2 waffles
Czed 4 waffles
huskihl 5 waffles
Lauren 10 waffles
PA Dan 2
Bilge Rat 2
P.M.P 2
Woodsliverdan 3
AlfA01
12:52 AM
Evia, Greece
Dub11 5 waffles.
redline4 2 waffles
Czed 4 waffles
huskihl 5 waffles
Lauren 10 waffles
PA Dan 2
Bilge Rat 2
P.M.P 2
Woodsliverdan 3
NPKenny 5 waffles
AlfA01 4 wafflies
jk14
5:52 PM
Glenside Pa.
Dub11 5 waffles.
redline4 2 waffles
Czed 4 waffles
huskihl 5 waffles
Lauren 10 waffles
PA Dan 2
Bilge Rat 2
P.M.P 2
Woodsliverdan 3
NPKenny 5 waffles
AlfA01 4 wafflies
Jk14 4 waffles
stihl livin
Do the Dallas
4:52 PM
Upper Midwest
Dub11 5 waffles.
redline4 2 waffles
Czed 4 waffles
huskihl 5 waffles
Lauren 10 waffles
PA Dan 2
Bilge Rat 2
P.M.P 2
Woodsliverdan 3
NPKenny 5 waffles
AlfA01 4 wafflies
Jk14 4 waffles
stihllivin 2 waffles
