eric4
- 10:55 AM
- Dec 23, 2021
- Northern CA
Howdy y'all! I picked up a 'parts' shindaiwa 488 a while back, as it was a nearly complete machine. All it was missing was the air filter + cover setup. The saw originally seemed to have gone down due to the rings seizing up in the piston, from ingestion perhaps?
I gave the saw a near-full disassembly, soaked the case, installed new rings, cleaned up the cylinder, base gasket delete, and muffler mod. The carb had dual adjustable jets, so I rebuilt it. When she was ready to fire up the first time, I got no spark. Verified I wasn't using a 'resistor' plug, then purchased a new ignition.
Finally after installing the new ignition system, the saw fired up! Ran erratically so I pressure tested, and it passed with 10lbs holding vac and pressure. I had figured it was my tuning, so I rebuilt the carb again, and tried to retune. Got the idle settled in, but once I give it full throttle, it can't find idle again and takes off on its own.
What would y'all start diagnosing next? Some things I'm considering are tank vent, bad fuel line, crank seals? A little stumped on where to go next, and the last thing I want to do is score up my newly cleaned combustion chamber.
It's a sweet lil saw that I hope to get running soon.
