Grimmy
- 1:11 PM
- Jan 8, 2016
- Traer, Iowa
So I'm what you'd call a weekend warrior. I cut for winter supply and that's about it. I do sharpen my own chains, and I've had some good luck, yet I've recently had some not so good luck. It's got me to thinking about how I'm sharpening. I been sharpening at 60 tilt, 25 twist on the holder, and I can move the holder to be on either side of the wheel (I think +10 and -10) I left at 0. I just started using my grinder to set my raker height. I will hand file on using the blue husky tool, and then matching my stone to that height and using the grinder to set the rest.
So what angles do you use? When doing the rakers, do you grind just one side, and then flip the chain over to do the other side, or does it matter? What do you set them for height?
This past weekend I was cutting some hack berry. I had 1 chain last 3 cuts and it was making dust. I'm thinking my chain was too aggressive and dulled itself, whereas if I would have had higher rakers it would have lasted longer. I'm thinking I need to go away from that tool and use a different one and stay at .025"
I've been sharpening this way for some time now, and the usual red elm and burr oak I cut, they work great. This other stuff though, well I'm unsure of what to do differently to be able to cut longer. Maybe my low kickback chain was in order for that stuff.
