- 6:46 AM
- Jan 24, 2017
- Berkshire County, Massachusetts
They are infamous for falling over lolNice gains.
Poor saw at the end of the 1st video.
Where did you end up with the timing, and did you take any pictures along the way ?Thanks!
I had some direction from some good dudes here
Looks like some super angle on the trans.
Best way I’ve found also
In your mind Mike, ask yourself the following questions:I do have a question, and not just re: Dan's work, I see it a lot … Why is everyone so concerned about not making the exhaust roof too flat, but then they make the floor flat? Isn't the ring just as likely to hang going down as going up???
IMO, a good bevel is the most important thing.
You are right Mike, you can hang a ring on the floor of the exhaust too.I do have a question, and not just re: Dan's work, I see it a lot … Why is everyone so concerned about not making the exhaust roof too flat, but then they make the floor flat? Isn't the ring just as likely to hang going down as going up???
It's an optical illusion due to the angle of the cylinder. The floor is rounded, too. Or at least it should beI do have a question, and not just re: Dan's work, I see it a lot … Why is everyone so concerned about not making the exhaust roof too flat, but then they make the floor flat? Isn't the ring just as likely to hang going down as going up???
Thanks Mike, yes it’s mine.Looks good Dave. Is it your saw??? Hope to see it at a GTG in the future.
