Saw video thread
Fruecrue
certified hand catcher
11:24 AM
Alden NY
I was actually asking about the 056 mag!
I hear you on the 460, sometimes it's fun to just see if it lives on your own stuff.
I have zero use for it, but keep searching for a deal on a Stihl 4xx series builder for some reason.
Alas, living in the land of $350 clapped out 029's and 455 ranchers, those be hard to come by reasonable. And when I have cash!
My bad, I have the slows.
I traded a member here for the 056 mag.
I like it a lot so far but haven’t done much with it, few test cuts is all.
Feels real solid and sounds great.
redline4
I'm huge in Japan
10:24 AM
Rosholt Wisconsin
Ppfftt. I went to wire wheel threadlocker off a couple bolts. Stopped at the water cooler and filled my bottle.
Went back to my corner to spend 15 minutes looking for the bolts I set on top of said cooler.
And found a 10mm wrench in my back pocket when I got home.
Mkinslow
10:24 AM
Tennessee
Sounds like a good, safe firewood tune. Cuts pretty well!
Thanks. Yes sir its definitely stronger. On the 2nd cut I started pushing HARD and it kept right on pulling, and same thing on the up cut,pulling up HARD and it just kept on digging. Before the work I could just about get it to stall out if I wanted too. I got it to do what I wanted with the porting I did, so I'm pretty happy with it.
Cut4fun
Redneck Chainsaw Repair
11:24 AM
Ohio
When a real machinist cant fix the screwed up cases from the shoddy work being done in the builders racesaws.
All 4 of the tapped holes are crooked for the key locking inserts.
What do you do = start over.
11:24 AM
Wow. Never thought I'd see that from Shawn
Hedgerow
10:24 AM
Lol!!!
That’s priceless!!!
Shawn needs his own pod cast..
