Saw video thread
Nutball
9:21 PM
Mt. Juliet, TN
The first time I used my 271t I did a lot of up cuts on the ground and the bar did creep down and over tightened the chain. So, I figured I'd center the bar so it won't get too loose or too tight on that saw.
sawmikaze
10:21 PM
steeltown
Skip is generally used on bars longer than 20". Like 32 through 36" length. I am only trying to help. I personally think your saw will cut faster using full chisel, full comp chain when using a 20" 3/8 bar with a saw that size.
Just me. 20" chains sharpen pretty fast by hand for me.
So i shouldn't use skip on my 14" bars on 201s ?
Chainsaw Jim
Con Artist LLC
7:21 PM
Springfield Oregon
I suppose if one was to do a short bar comparison between full comp and skip, both off the roll, they'd have slower cut times with skip. But a skip chain should be set up a little different with lower rakers. They can move.
