Saw video thread
1:33 PM
I'm open minded … others can do what they want … does not mean I have to follow. I won't tell others not to do it.
I hate loose chains, and I hate having a chain come off the bar. Often the drive links get damaged, and it is lots of work to make them useable again.
Nutball
12:33 PM
Mt. Juliet, TN
I haven't run my big saw in a few months, and all this recent talk and research of porting for me makes me question my saw's abilities, so I had to check and make sure.
Not bad, I'm still happy with it.
<iframe width="560" height="315" src="https://www.youtube.com/embed/w5EY64_qvBc" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
18" Ash wood (under the bark), 8t rim, 20" Stihl skip
Nutball
12:33 PM
Mt. Juliet, TN
Skip: so it doesn't take as long to sharpen, and to experiment if I could get it to cut faster. Maybe on a long bar, but I find it's been equal to or a bit slower on short bars. Now I have a bunch of 20" skips to use up. That particular chain started out with the depth gauges low enough to put a max load on the saw in a 20" cut without having to use any pressure, maybe even holding it back a bit. I have since sharpened it a bit because it was a bit too aggressive (frequently stalled in oak when making face cuts), it works pretty well now, I have more control over cut speed and rpm. It's my bucking chain, no bore cuts even remotely possible. Just a different "gearing" than normal chain, similar results, different handling.
There was risk of rain, so I had my 1080p camera around 50ft away in the garage with like 25x zoom. I like to line up with the end of the log and zoom in for more accurate timing. 112dBA for bystanders (you see the sound meter in the video).
1:33 PM
Skip is generally used on bars longer than 20". Like 32 through 36" length. I am only trying to help. I personally think your saw will cut faster using full chisel, full comp chain when using a 20" 3/8 bar with a saw that size.
Just me. 20" chains sharpen pretty fast by hand for me.
Nutball
12:33 PM
Mt. Juliet, TN
Thanks, I understand, but 20" skip sharpens even faster! Just an experiment. Plus with city tree work I'm at high risk of hitting metal which means a LOT more filing on each tooth
