Saw video thread
Imprzed205
11:10 PM
Atl
It does now you mention it lol. We had a cold front last week then 80's this weekend so the fish wasn't hitting on anything today.
10:10 PM
I do it every week started mid march til maybe end of October.
t4driller
Daddy Day Care
11:10 PM
Southwest pa
Learn something new every day. May have to try your bucking technique...
I learned that from a video on here. Can't remember who it was now.. but I've been doing it ever since then. No more pinched bars. [emoji4]
TreeLife
I'm Dominick
11:10 PM
I use a similar technique when bucking big logs in a pile. If the pressure is on top and the tension is on the bottom I cut a couple inches into the top, leave the first 4 inches of the bar in as I cut down the side for about 3 inches, then I bore thru and finish the bottom cut. Snip the top to finish :-)
t4driller
Daddy Day Care
11:10 PM
Southwest pa
I will try that sonerime to..it all depends on where the tension is on the log whether I leave some meat up top or bottom. I used to just cut from the top and wait til the cut starts to close, then pull out... [emoji6] then try and roll the log over to finish the bottom. With that technique it saves alot of time and unnecessary work trying to roll the log over..
Duane(Pa)
It's the chain...
11:10 PM
Centre County
That, and it's really hard to pull out when you're bucking...
TreeLife
I'm Dominick
11:10 PM
Pulling out like that leads to babies...
