Saw video thread
12:27 AM
I think the issue of reciprocating vs. rotational balance is what caused a difference in opinion with balancing and pistons.
Also, when the crank pin is at 90*, how much percentage of the rod of is adding to the rotational weight?
The guy in the vid knows his stuff. I guess the goal is to keeps the vibes out of working rpm.
94BULLITT
12:27 AM
VA
Not trying to argue, but why is there a counterweight in the crank if the piston and rod cause not rotational load at all? Why not just simple crank with no weight or a full circle to take up case space?
On auto cranks, the piston, rod and rings are weighed and a bobweight is attached to the crank of equal weight to balance the assembly. On a boxer engine, perfectly opposed, I believe there are no counterweights on the crank. On a straight 6, there's a counterweight for each cylinder.
I think it does apply force, but its so little that a difference in weight is hardly noticeable in a saw.
Just my $.02.
Has anyone complained about the vibration from a full circle crank?
Sent from my SPH-L710 using Tapatalk
12:27 AM
Guess it would depend on how the crank is made.
The custom ones I've seen involve a lot of epoxy, so the weight isn't perfectly distributed.
Here for the Yum Yum Sauce
11:27 PM
Hey guys, been reading this a bit, so when I was on the phone this morning with a fella that worked for a major two stroke manufacturer doing R&D on engines. So I asked him the balance question. Contrary to what I had thought, he told me that the whole assembly in its entirety is balanced. He also said their is a small amount of wiggle room of tolerance that an engine will take being out of balance. Boring out engines with standard weight pistons would stay together at about .050" overbore, after that they usually broke rods at high RPM. Also vibration increased the larger they went. Above the .050" overbore the crankshaft would have to be rebalanced to keep it running long enough for testing. They also tried other manufacturers pistons in their twin cylinder engines and said both had to be used as no two manufacturers had the exact same weight piston. When asked about a 2mm big bore kit for a saw, he figured that must be a lightened piston to get close to the range of its 2mm smaller counterpart. Then the conversation turned to different subjects.
For myself I would be curious if this were to be true, would like to weigh a piston from a big bore kit and compare to a standard one and see how this shakes out. Interesting subject to be sure, for a side note those engines he worked on were anywhere form 250cc to 440cc singles and twins, so some interpretation is needed in the translation to a saw that is say 35cc to 100cc. My guess is the smaller the engine, the smaller the weight change the more tolerated by said engine. Then again WTF do I know about it.LOL
Hope this helps shed light on this for some of you and not muddy the waters further as it is not my intention to, really, it's not...
12:27 AM
kinda the same as i thought and posted a few pages ago thank you stump shot
jmssaws
Banneded
11:27 PM
I just finished putting a 046 54mm bb on a 044 and the piston was very heavy but I ground it down to size.
I have a full circle crank for a 660 that's very heavy and you can't tell any difference in vibs.
I have built some 064s that were likea jackhammer.
