- 9:26 PM
- Dec 30, 2015
- Centre County
Did you try reducing the pop off pressure? Or at least check it?562XP after new bottom end and minor port work... timing is a bit too advanced as you can hear in the video. Has an EL 46 I tried to “mod”to get rid of the bog. Didn't help.
I haven't tried that yet... I’ll give that a tryDid you try reducing the pop off pressure? Or at least check it?
She can tighten my nuts so my bar dont droop any time .A cute female - CHECK
A chainsaw - CHECK
A Stihl - uhm, half point
A MS661C - no points
A piss revving - CHECK
Bonus - An adorable puppy - CHECK
TOTAL: 4.5/6 , not too bad
Somehow I think those two are not into bar nuts .this two can handle a bar or two.
Nah just bigga tuffa chain and a saw to pull it lolYou need a bigga saw mate. Lol
This is what I mainly cut for sale firewood it's tough on cutting gear as it is just about always got piss ants in it here on the coast .404 Territory all the way .Home owner saw madness! lol
Gave a couple of my big gun saws a run for a bit of fun and to give em a good workout the little ms170 and ms211 it was tough going was hard old dry dirty Stringy Bark hardwood.
The piss ants had taken heaps of coarse granite sand into the log it smoked my chains after not many cut's the ms211 was done after 2 cut's.
Chain was full chisel 3/8 low-pro on both saws.
ms170
ms211 chain was done after the 1st cut you can see the sparks in the 2nd cut from the coarse granite sand.
I'll be going back to finish cutting the log up with some .404 and 121cc
That's some dirty looking Stringy ya got there is burnt and even got dirty white ant chit up the guts. I find the white ant chit isn't to bad if it's wet but if it's dried out is hard on chains smokes even 404 almost uncuttable I usually walk away from stuff like that lolThis is what I mainly cut for sale firewood it's tough on cutting gear as it is just about always got piss ants in it here on the coast .404 Territory all the way .
although these next to vids are 32 inch with good old hurricane full skip 38 semi chisel that chain cut this whole tree and we got 8 m out of it just with three sharpens best cheap Chinese crap I've ever used .
Ms460
Ms461
