Saw builds
Brewz
1:24 PM
Hunter Valley - Australia
I love the velocity stack and K@N filter option.
I have them in a few saws.
They do make the saw louder at the user end though.
I have just fitted this max flow to my 064.
I had a buggered HD filter that I removed the filter material from, leaving just the plastic cage.
The max flow fits over it perfect.
I then cut a piece of 3mm thick Perspex and drilled it to hold a captive rear cover nut.
Will work great for bugger all cost.
Fired up the saw and its picked up a couple hundred rpm at idle over a clean HD2.
More air means more fuel means more power!
11:24 PM
If a guy wanted to play with vstacks and air filters, you can get a vstack on ebay for scooters for about $7, but the inner hole needs to be made a bit larger. Piece of cake with a burr and sanding mandrel. And an aftermarket angled double foam filter with a fernco style connector is like $6. Works dandy on an 066
Brewz
1:24 PM
spot on!
Search Walbro velocity stack
They are made for 1/5 scale RC cars
just bore out the center to suit.
They usually came made to fit the carbs used on the 026 so the hole is small
Definitive Dave
Piss Rev Mafia Member
11:24 PM
Central Ohio
I ordered a larger assortment of unifilters this time to hopefully offer some options for the different V stacks.
On the DRF255 026 I shortened the green weanie so it didn't stick up so far, the spring and foam can both be shortened easily.
I like it better without the AF cover and a lot more air than stock :)
Dave
