Rotella 15w 40 oil in a B&S?
Nutball
5:53 PM
Mt. Juliet, TN
What do you think of Rotella T oil in a 12.5HP Briggs vertical shaft engine? Someone changed the oil to that, should I leave it?
Inlineforagoodtime
6:53 PM
Earth
I use 5w 40 in my splitter engine and it works just fine. If the temp dips below freezing you might want to pull the engine over slowly before pull starting. It might help with the longevity of the pull rope.
Stem
Professional Cup Stacker
6:53 PM
Pennsylvania
splash lube engine or pressure lube? it'll be alright for warmer temps. normally run 10w30/40 & 5w30 for cold temps.
FederalQ
5:53 PM
NE Wisconsin
I have used 15W-40 and 5W-40 diesel oils in my 12.5 hp Simplicity splash b&s engine for years. Mostly used in the summer. The mower is over 30 years old now.
Nutball
5:53 PM
Mt. Juliet, TN
I thought they were supposed to take non detergent oil. I plan on storing it in the garage and can preheat the engine with a diesel heater.
jblnut
Flabs of Stihl
5:53 PM
Central Mn
Everything on the farm from the push mowers to combines and minivans and skid loaders get 15w-40 all year long. Never had an issue we traced back to oil. It’s much easier just having one big tank of oil to pull from.
I’d say run it.
6:53 PM
That particular 15–40 is very good at cleaning up carbon left behind from not changing other oils often enough. I have seen Honda 1000 and 2000 W generators burn oil and shut down before they ran out of gas. Changed to Rotella t 15w-40 and the problem went away instantly. Oil was black after 10 hours run time. The detergents in it are amazing
SawAddictedFarmer
5:53 PM
I can tell you that guy is a idiot if he's blaming it on that oil. If fun that exact oil for 1800 hours in a pro ztr with no issues. BTW it's not letting me play the video but it's probably just my internet.
bigbadbob
3:53 PM
Interior BC Canada
I run 15-40 in my mower and honda ATV,,log splitter and other things
It meets all the specs...
the honda atv has a automatic and specifies non friction mod oils.
as the engine and trans share the oil. Rubicon atv 2001
6500 miles,, no issues.
Mower is 35 or more years old.
Lions fan
6:53 PM
Cheboygan, MI
I use the bulk 15w-40 Chevron Delo we stock at work in my tractor and wouldn't be afraid to run it in my small equipment if I felt the need for 40wt. oil. I don't own a German sports car, but if I did you can bet your ass I'd be running exactly what the manufacturer specified, especially in a DFI engine.
FergusonTO35
6:53 PM
Boonesborough, KY
I'm a big fan of Delo full synthetic 15w-40 in all my off road 4 strokes, gas and diesel. If they made it in lower viscosity I would use it in my car and truck.
Lions fan
6:53 PM
Cheboygan, MI
Pretty sure they offer it (XSP) in 5w-40 and 5w-30. I know for a fact they make the semi-synthetic (XLE) in 10w-30.
Junk Meister
5:53 PM
Nebraska
In the early '80s' we had a 3/4 ton 2wd Chevy come into the shop doing that hard to start from excess oil usage and smoke. For some reason we put 20/50 Valvoline "RACING" oil in it. Beat ourselves out of an overhaul job. We tried tat oil trick on ford and Mopar but no luck. started selling a lot of Valvoline for some reason. This truck and other successful brand changes were the 350 small block not that 5.9 DSL. The 292 were bullet proof so never tried it on them.
drumbum
5:53 PM
Goodlettsville
I hope nobody tries to "throw a lit match in a bucket of gas" from the info in this vid.
Sheesh. You will be wearing a flaming gasoline suit.
The 15-40 oils I have run and looked at say for diesel and gas engines. They are considered HD oils for longer change intervals.
Most car oils have zincdiethlydithiophosphate levels of around 800ppm where the diesels hover around 1200. The increase of zddp is to account for the higher detergency. The charts referring to calcium and phosphorus levels might be misleading to boost sales of ????
Modern oils are designed for modern engines,...i.e. multi valve OHC engines with much lighter spring pressures than old school big valve heavy valvetrain engines.
Look at the recent engine track record of BIG AUTO,....and the rep of comp cams and lifters.
Eat the meat and spit out the bones.....and read the fine print on the meat prior.
As to my first comment about the bucket of gas,.....I'm sure the guy misspoke @ 3:30 mark and meant to say a "lit cigarette",... as gasoline needs spark or open flame to ignite the vapor.
Again,....YMMV.
...except for the bucket of gas part.
Would you take advice from this "expert"?
...and to think this polished vid was edited. Ain't yootoob grand?
drumbum
5:53 PM
Goodlettsville
Again,....YMMV.
I just read some of the comments at that vid....lol
