Ronie's 660 kit saw
Ronie
4:01 AM
NC
I saw that, If I don't cut the base and do a gasket delete it won't free port. This cylinder has a smaller combustion chamber than the Hyway so It might make good compression with just a gasket delete.
Ronie
4:01 AM
NC
I tried cutting the squish band and it didn't go so well, I think when I get to the bore the whole cutter is making contact and I need to raise the cutter up some or turn it a little, it sucks but I'll get the hang of it. I ordered a new cylinder and it will be here friday.
3:01 AM
You can fix that I think. What shape cutters are you using?
Member
3:01 AM
Looks to me like your boring bar is a little too high or low, try centering it better in the cut.
4:01 AM
4:01 AM
But no matter how you do it, any plated squish band absolutely sucks on a small lathe. Fortunately a 562 and 572 are about the only oem cylinders I can think of with anything measurable on the band.
BuxtonSaws
3:01 AM
Wisconsin
It was already mentioned.. but to me it also looks like you need shims under the bar. I run slightly above center.. I'm no machinest though. I learn from trial and error... My ways are not always correct.
Sent from my Pixel 4a using Tapatalk
Ronie
4:01 AM
NC
Finally success, I spent the morning trying to figure out how to get my tool rest raised up high enough and after 3 times having this cylinder on and off the lath, I think I got it. This is the Farmartec cylinder that came with the kit, it looks like I made a small squish band but the second time I had it on the lathe I wasn't cutting all the way to the bore and I didn't cut it quite as deep the third time I had it on the lathe. So I raised the tool rest, shimmed the bar and set the bar at a little angle. One other thing I did was to put another dial indicator on the tool rest so I could see when I was at the bore. Thanks for the help@Mastermind, @Stump Shot, @huskihl and @BuxtonSaws. If I forgot anyone, thanks to you too.
