Ronie
Not really a build thread, just documenting it's progress and I'll probably have some questions because I've never put one together. My plan was to put an OEM PTO bearing and a Nachi flywheel side bearing in it but for some reason I put the bearings on opposite of what they should be on the crank and messed them up when I took them off, so it's getting Farmertec bearings.
To put the crank in, I ended up poping the seals out, put the oil pup on and heated the case in a 250 degree oven for a 1/2 hour. I did the clutch side first and layed a .025 shim between the case and the lobe, I think it would have been fine without the shim. The crank slid right in both sides without a problem.
Added note: I used a Hyway case gasket and will be using Hyway seals.
