- 4:01 AM
- Dec 30, 2015
- Brewster, NY
I have sometimes had carb tuning problems that made me think I had an air leak.
I don't know, it just bugs me. lolThat burble is concerning?
It was like srcarr52 said, I increased the pop of pressure and the burbling after the cut went away.Maybe the cylinder is getting too hot because FT and Hyway and other chinese cylinders often have poor air flow because the fins are super thick at the casting seams.
With I could help you with the why but I have no Idea.That's good. I wonder what the science is behind that change and how it affects that burble. I may be way off, but it sounded to me like it was getting too little fuel when spooling down, like there's an air leak in the main nozzle check valve, or it was too hot. Was it getting too much fuel instead? I don't know much about internal carb adjustments.
That probably came off of your table
I wasn't real happy with the torque of the Hyway cylinder so I decided to try a big bore cylinder and see what it's like. It's just a cheap white box cylinder but it doesn't look to bad. I'll put up the timing numbers once I get the saw apart and the wheel on it.
View attachment 305862I guess you won't have any free port issues.View attachment 305864 View attachment 305865 View attachment 305859 View attachment 305860 View attachment 305861 I wasn't real happy with the torque of the Hyway cylinder so I decided to try a big bore cylinder and see what it's like. It's just a cheap white box cylinder but it doesn't look to bad. I'll put up the timing numbers once I get the saw apart and the wheel on it.
View attachment 305859 View attachment 305860 View attachment 305861 View attachment 305862
It might, I thought all the 660 big bore cylinders had free port issues.I guess you won't have any free port issues.
I see what you mean, because the piston is in the cylinder in the pic at 0 squish and it's not free porting.I guess you won't have any free port issues.
