NorthcentralYooper
- 6:49 AM
- Dec 24, 2015
- Upper michigan
Hi I'm working on a husky 51 Epa 49cc this has a pulse port and pulls air in from a notch in the gasket .
I read someone deleted the gasket on one of these and never mentioned any details other then it ran good.
I'm removing the H limiter on the carb I checked squish and without the gasket I'm at .030" has anyone ever worked on a solution to running without a base gasket.
The current one is .009 " so I could use brown paper at .004" but would that even be adequate for a air gap to draw air?
My solutions would require machining but maybe I'm missing something.
Thanks !
Thanks !
