9:16 PM
Have you found anymore of those in a line ,like they are pointing a direction to something?
Not really. Of course there are now fields and roads all around......
But I get what you are thinking.
redline4
I'm huge in Japan
9:16 PM
Rosholt Wisconsin
I did my end of the repair correct, I just ended up cutting out the spliced in bs on that side so his lights would work.
When he pretty much said I was the one who jacked his wiring up, I walked away. And went for a walk around the lot.
Maybe he should go talk to Captain Stabbin of the test light brigade.
Steve
Excellence!
9:16 PM
@Dub11
You was asking about the multiple cylinder displacment and was scared cause of the stories Ed and I are always posting.
Here is hondas system. They just lock and unlock the rocker arms to disable cylinders. You can see the lock pins in the center of the rockers. The springs are to keep zero lash on the cam while unlocked so they arnt slapping away making noise. The only failure i have seen on these are that little blue pressure switch. Fully assembled they each take less than 5 minutes to replace.
9:16 PM
I heard of this project on NPR one day.
And yes I love me some NPR.
@Dub11
View attachment 170879 View attachment 170880 View attachment 170881
Nice I guess I should of done some more research before righting them off.
Do the Hondas have a trans dipstick? The Yota doesn't.
Well since I missed 346, 351, 353, 357, 359, and 360 I guess I'll get in on 361. Watch it post on 362 lol.
Bro you're slipping! I see missing paint on that bar:eek:
Bigmac
7:16 PM
Oregon
@Dub11
In theory I like the old bmw I6 with variable rocker ratios, I know it’s not displacement on demand, but I like the idea of a small valve lift at low rpm’s that increases ratio with rpm to create a seamless transition and big valve lift in high rpm! I wish they would have done that to the ls motors
chipper1
10:16 PM
Grand Rapids Mi
That’s a clean one!
It's not bad, but a small crack in the cover, it was ported by Terry Landrum(anyone know what happened with him).
I'm not sure what bar that is, I normally run a 20" ESlight on it.
Do you like this one better.
9:16 PM
That ain't fair lol.
Over head cams do have there advantages.
Steve
Excellence!
9:16 PM
Bmw i think still does that. I havent had one in for awhile but that system was pretty simple with no major problems. The N52 engines had an eletric motor in the valve cover that moved an eccentric shaft to change the ratio on the rockers. Those engines ran very well.
