- 9:44 AM
- Feb 26, 2017
- Belleville, Ontario, Canada
It's kinda funny that @PA Dan and I were talking a few days ago about recording all the port timing numbers in various 262XP cylinders, then running them all back to back to see what numbers worked the best. And here you are doing something along the same lines. Good stuff!
That's great - thank you Dan!I use this program to save on more math...
http://torqsoft.net/piston-position.html
There are a few things that need to be considered when using it.
It calculates from distance from top of piston at TDC, to port opening.
So squish measurement is involved, as well as piston height for the intake.
Also I measure from the base down to the ports and need to convert to piston down.
I do this because I can get a more accurate measurement this way.
Have you ever cross checked the mathematical compilation with the degree wheel for accuracy?
Sort of double checking your measurements.
Wow. From my screen looks like KS jug has bigger tunnels and bigger ports.
Base gaskets:Love this thread! Anyone know the number for the thinnest base gasket for the 262? I think I heard it was for a 254 or something? @Tor do you know?
Thanks Chris!Base gaskets:
503 48 70 01 = thin gasket
503 48 70 02 = thick gasket
Try a 106.5 Ex and a 78 intake Dan. The intake already has more area stock than the intake tract, so just lower the floor and round the corners into the factory vertical sides. You’ll be a happy man.
Thanks for taking the time to do this.
Do you find the KS to have bigger transfer tunnels than the Mahle? That’s what people claim. I can’t tell if it’s an illusion or not.
