Quoted a big red oak today.
fearofpavement
1:15 AM
Georgia
So today I heard back from a vacant house with a tree problem that I had left one of my cards at.
I gave a quote for removal of this mess.
I need some run time on my saws so hope I get the job. On the other hand, it's hot as blazes this time of year in this part of Georgia....
fearofpavement
1:15 AM
Georgia
That's a big stump to get rid of ,does the landfill take stuff like that in your area ? or do you need to get the dirt out and chip it up ?
I bid the job with and without removing the rootball. If I need to move it, I'll bring a set of forks for the Bobcat 873 and poke at it quite a bit to knock as much dirt as possible off of it. Then I'll load it on my equipment trailer and dump it somewhere on my property. I've actually been able to burn root balls like this if there's enough other stuff to burn with it...
It is a big job (more than one day for Groundi and me)
It is insurance work (at least a portion of it) and he has to submit his bids and see what happens with that. I'd like to get this job because it's close and it's a lot of saw time which I need to test some saws.
Looks like I'll get the Stihl 070 out for this one too.
We'll see, I have competition on the bid but I work pretty cheap. I told them I would remove the whole mess for $1350 including the root ball. If someone bids less than that, I'll gladly let them do it instead.
I don't need firewood at all so there's no attraction for that aspect. (it's a red oak)
fearofpavement
1:15 AM
Georgia
Here's a pic from the top end. One of the buildings that got flattened isn't even visible in the pic.
exSW
'Cause Thomas is a poopyhead
1:15 AM
United States
You didn't put that stump on the low boy with that little track hoe did you? I'm thinking a pretty good size excavator to lift one of those...
edit: now that I look, I can see it's not the same stump so nevermind...
Grove version of a Pettibone.
fearofpavement
1:15 AM
Georgia
what do you think that stump weighed? Maybe 7000 lbs or so?
exSW
1:15 AM
United States
Man,that's a good question. I whittled on it until it no longer lifted the rear tires of that machine. I'm going to say more than 7000. In that pic you can see the rear downrigger getting a little air.
