- 5:33 PM
- Dec 31, 2015
- East Jordan, MI
The one I did for you is probably 108....Thanks! After doing the exhaust, I started having second thoughts on making it so high.
That saw has got gobs of torque.The one I did for you is probably 108....
Looking around the forums for post about porting a 346, 102 is the highest exhaust number I found and since I was looking for rpms I thought I' give that a try. If it doesn't work out, lesson learned. lolThe one I did for you is probably 108....
Just depends on what you want to cut.Looking around the forums for post about porting a 346, 102 is the highest exhaust number I found and since I was looking for rpms I thought I' give that a try. If it doesn't work out, lesson learned. lol
Just smaller stuff, it's mostly just something to play around with.Just depends on what you want to cut.
I think you’ll want the transfers up in the 118-120 rangeJust smaller stuff, it's mostly just something to play around with.
Thanks, I'll give that a try.I think you’ll want the transfers up in the 118-120 range
Love them uppers Shawn !!View attachment 270430
Nice Al! Bet she will run strong!Finished a 261CM today. The little peanut ports are a PITA.
These transfers were raised over 10*, both primaries and secondaries.
View attachment 270580 View attachment 270581 View attachment 270582 View attachment 270583 View attachment 270584
Coming along nice bub.View attachment 271111 359XP . Didn’t raise/ lower anything just made the exhaust port larger, messed with the lowers a little bit. Sometime soon I will get a piston so I can time it and go further with ze porting.
And if you guys have any suggestions on what I should do, let me know. I am always open to advice.View attachment 271107View attachment 271108
Nice work Austin! Going to be many screamers coming out of the Barretts Brap shack!View attachment 271111 359XP . Didn’t raise/ lower anything just made the exhaust port larger, messed with the lowers a little bit. Sometime soon I will get a piston so I can time it and go further with ze porting.
