Post up your ported cylinder Artwork
Lightning Performance
8:36 AM
East of Philly
Hitting your numbers doesn’t come easy on your first one. Your so concentrated on grinding it’s easy to lose track.
I sneak up on the last line on the jug with a sanding roll in the exhaust and intake. The transfers get finished with a stone sometimes or a dull burr.
How does it run now on your mill?
ranchdadmike
8:36 AM
AL
redlight066
8:36 AM
Taylors SC
Redmax G9000. Still lacking on getting my uppers looking beyond average. Jug had pretty decent numbers stock. Deleted the gasket and took .030” off the base. Ended up at 80/121/99 with squish set at .023”. Lightened up the piston a little as well.
8EA3A630-C98F-4802-B6D0-A43C7E75A65D.jpeg 262357F7-A095-4A61-93A4-B5D6E06D3CD3.jpeg F6B88322-281E-438A-9C60-AC1F38C075D5.jpeg 3F8F2B61-D9D6-45E3-9485-62385E755CCD.jpeg
Ketchup
Epoxy member
6:36 AM
Colorado
It’s prolly more the air powered 90. It’s a little clunky to do fine work. The kit from CC is awful pricy.
View attachment 253803 View attachment 253804
FWIW, I’ve struggled when my burrs are dull or loaded. Can’t really tell the condition of those but it’s important they’re sharp and clean.
I switch to diamond burrs when I’m getting close. It slows me down reduces the chance of a sudden mistake.
markds2
2:36 AM
Nelson, New Zealand
Is that a Foredom Right-angle? I've looked everywhere on the Foredom website and nowhere can I see the right-angle heads you guys all use. Where can they be purchased? If it isn't a Foredom, is there an air-powered right angle that is small and compact enough to reach into at least a 50mm cylinder?
srcarr52
8:36 AM
Iowa City
I don't believe Foredom actually makes a right angle hand piece. CC Specialties sells what you are looking for. @srcarr52 may have some info on this.
The CC Specialties 182MC is what everyone uses. Foredom used to sell some latch burr (dental style) heads but they'd last all of a hot minute grinding transfer ports.
