Post up your ported cylinder Artwork
sledneck22
But, is the chain sharp?
5:04 PM
WI
What are you guys using to polish your ports? mandrel with sandpaper or a sanding disk of sort? I read someone uses a buffing wheel and valve lapping compound. Just curious on what might work better than other ideas.
6:04 PM
Foredom with 80 grit in a mandrel
Shibby
4:04 PM
USA
I like this a lot, especially for cylinders that do not have a lot of material. Do you have an idea of how much it reduces compression having a small patch of the cylinder missing? I'm sure it could be offset with a pop up top. Would it be better to widen/square off the exhaust port or leave the original shape and notch the piston like this?
