Porting Tools - Need Some Help
Tor R
Novice, Leg model #2
7:41 PM
Mandal
I've had a Dremel for well over 20 yrs. Twisted off many cables over the yrs and still going strong.
their Fortiflex system look very interesting. I asked them if I could use Foredom&CC handpieces, but they couldnt answer.
Ended up to buy a Foredom kit from CC.
Tor R
7:41 PM
Mandal
Sorry, I forgot you are in Norway.
CC Specialties is a supplier of all sorts of porting tools. http://www.ccspecialtytool.com/Default.asp
McMaster-Carr is an Industrial supplier here in the states.
I've also got diamond points for a seller on Amazon. Lasco Diamond Products, Inc.
Here is one I use to bevel ports.
I've bought from CCSpecialty before, I guess those expensive diamond burr they have last for quite some time compared to chinese burrs.
I have two options as I can see, either buy 3mm collet for my 182 handpiece, or buy expensive diamond burr.
Those diamond burr will only be used to bewel ports with, so I guess I can survive the cost of quality.
srcarr52
1:41 PM
Iowa City
I've used the same diamond burr for 3+ years. They last a long time.
I use a Foredom #8 handpiece and a 3/8" diamond ball burr to bevel ports. No need to use the right angle to do it.
Tor R
7:41 PM
Mandal
I only have Foredom #28 handpiece but I guess it should work out.
3/8" diamond ball, do you use it to bewel port even on 346 OE's or do you go for a tad smaller ball burr for bewel TR ports?
srcarr52
1:41 PM
Iowa City
The #28 handpiece will work fine. I use the 3/8" ball to bevel even small cylinders.
Tor R
7:41 PM
Mandal
Thanks Shawn and Randy :)
jmssaws
Banneded
12:41 PM
I have 3 foredome Sr and a grizzly high tourqe,haven't used the grizzly much but I've used a foredome about every day for many years,most days for several hours and all I have ever done is replace brushes and broke shafts. There hand peices are superior to any I've used.
I'm gonna try a prodigy because I hear there good too.
Foredome is hands down the best I have used.
super3
1:41 PM
Indiana
I have a Foredom also, grind with it. Dremel and Roto Zip flex for sanding and cratex.
Only thing I don't like about the Foredom is it takes a looooooooooog time to stop spinning.
I have always wanted to adapt a Foredom flex to the Roto Zip, lot more speed and stops almost instantly.
srcarr52
1:41 PM
Iowa City
Mastercarver handpieces make Foredoms look crappy.
srcarr52
1:41 PM
Iowa City
Never heard of them.
Foredome is the only handpiece I've used that runs pretty cool, the cheap ones get hot fast and I hate that.
I'll give the mastercarver a look,thanks
The bearing bosses are misaligned and not deep enough on the cheap ones which causes the extra bearing drag. I've remachined a lot of them to get rid of that problem.
