TexasJohnny
- 11:46 PM
- Apr 5, 2025
- League City, TX
Hey y’all. Don’t want anyone’s secret numbers or theories, etc. just need general porting advice.
I’ve ruined two cylinders so far and what always gets me into trouble are the upper transfers. The right angle hand piece I have is one of the Amazon cheap ones. I’ve tried the double cut burrs but I’m jumping out and scoring the crap out of the cylinder.
I’ve figured out finally that lower rpm’s and a lighter touch is best - you think I could raise the upper transfers with a diamond burr instead? Or should I go less aggressive with like a sanding drum.
If y’all suggest diamond burr what shapes work for y’all? I’m working a CS590 and a 501p if that helps knowing the size of the uppers. Any other tips would be helpful and much appreciated!
Edit to add: I’m using the now junk cylinders for practice as well.
