Porting help don’t need/want #’s
TexasJohnny
2:19 AM
League City, TX
Hey y’all. Don’t want anyone’s secret numbers or theories, etc. just need general porting advice.
I’ve ruined two cylinders so far and what always gets me into trouble are the upper transfers. The right angle hand piece I have is one of the Amazon cheap ones. I’ve tried the double cut burrs but I’m jumping out and scoring the crap out of the cylinder.
I’ve figured out finally that lower rpm’s and a lighter touch is best - you think I could raise the upper transfers with a diamond burr instead? Or should I go less aggressive with like a sanding drum.
If y’all suggest diamond burr what shapes work for y’all? I’m working a CS590 and a 501p if that helps knowing the size of the uppers. Any other tips would be helpful and much appreciated!
Edit to add: I’m using the now junk cylinders for practice as well.
singinwoodwackr
1:19 AM
moon
Keep practicing.
EFSM
2:19 AM
Extreme southern IL
The ramped intake side transfers on those cylinders are weird. Some people square them up and turn the roof into a normal flat profile but I use a flat ended diamond burr in a dremel to evenly grind the roof to maintain the angle. As far as right angle hand pieces, I found that high speed actually benefits me because there is less time for chatter. The key is to take it slowly.
srcarr52
3:19 AM
Iowa City
Single cut burrs will chatter less.
I use this in large dual ports when it will fit.
Then I use something similar to this for smaller transfers.
TexasJohnny
2:19 AM
League City, TX
Thanks for the suggestions y’all, I’ll keep at it - got two new echo cylinders coming in the mail - won’t touch my Stihls until I get consistent results with the cheaper echo cylinders.
Again, thank you for the responses!
TexasJohnny
2:19 AM
League City, TX
Sorry guys been working turn arounds and projects - whelp I got my 501p back together last night finally and pretty sure I hung a ring on the exhaust. She’s stuck like chuck. Sounded good for a few seconds though.
yalls tips helped me a lot and I appreciate it. Next cylinder I’m just going to set the squish to .020 and see how she does. Maybe scuff up the intake and try the exhaust again (less is more).
As a newb it is hard not to grind way too much. It’s kind of like trading stocks, you know when you’re getting emotional and chasing but you’ve got to learn to deny the urge to pull the trigger and wait or you’ll just lose.
I’ll try to tear it down sometime this next few weeks and post pics of my attempt so yall can have a good laugh. 🙂
