Nate6421
- 10:28 AM
- Nov 6, 2022
- Newark, DE
Do you know where I would be able to get a check valve? and how I would know which size?I thought I heard somewhere why the 355t sometimes goes a bit lean coming down from idle. I had one do it, then it stopped. Many saws will get somewhat lean at half throttle. The carb might just need a different main nozzle if it is using the thin black rubber check valve that also causes many 590's to have lean idle problems.
