Porting an Echo 355T
Nate6421
5:08 AM
Newark, DE
I thought I heard somewhere why the 355t sometimes goes a bit lean coming down from idle. I had one do it, then it stopped. Many saws will get somewhat lean at half throttle. The carb might just need a different main nozzle if it is using the thin black rubber check valve that also causes many 590's to have lean idle problems.
Do you know where I would be able to get a check valve? and how I would know which size?
Nutball
4:08 AM
Mt. Juliet, TN
I'm not a carb expert, so you should start a new thread about finding a better check valve/ main nozzle for your carb, and someone else will point you in the right direction.
EFSM
4:08 AM
Extreme southern IL
The mid is always lean, I can get the idle great, and top great, mid is always lean.
Aside from the lean mid, the saw runs great if you are comfortable with the chain takings a couple seconds to come down to a stop. Which I want to fix.
Maybe you all know this already, but Echo changed the 355 air filters to a mesh style filter. They run like a totally different machine and idle/rev up and down way better as well as more power. The paper filter was far too restrictive because it would suck in against the anti-spit plate.
Nutball
4:08 AM
Mt. Juliet, TN
I don't think it's a filter problem. I think it's an air leak problem either caused by a bad carb design, or improper porting or engine assembly.
Nate6421
5:08 AM
Newark, DE
I didn't do all the work at once, the first thing I did was the port matching and rounding sharp angles in the muffler (no extra outlet) and popped the limiter caps. Its had the issue since then. Also, when I did do the exhaust port work, I cheated and didn't disassemble it, just stuffed a rag above the piston, then blew it out well, so its not from improper assemble.
I believe its bellhopper on YT who did a couple videos porting a 355t and had the same issue with a lean mid.
EFSM
4:08 AM
Extreme southern IL
You may be right, especially if this is a high use saw. However, I had a nearly-new 355 that was running similar to what's being described here, and the updated filter fixed it. I chased that issue for hours before figuring out what was going on.
