porting a 064 hybrid.
Stihlbro
11:28 PM
Virginia
ok, for the not knowing - whats up with the extendo pull starter handle? Some type of spring in there?
You generally see that on a saw that is built to do what is called cold start racing. Saw is not running sitting on the ground, and at the proper cadence you have to start saw and cut. The extended starter rope makes accessing the handle quicker.
