porting a 064 hybrid.
jmssaws
Banneded
12:49 PM
When I started building pipes for a lot of racers I have learned a lot of things....five cubes like a lot of rpm....stroker 3120s on nitro don't turn the rpm that you think they do
A short bar saw is kinda out of my element, I'm curious if a strong long bar saw with a big sprocket is faster or slower than a big rpm saw. Sorry for all the questions guys.
1:49 PM
Which one though?
Don't madsens have the formula to calculate chain speed on there site?
There has to be a point where tourqe will out weigh rpm. I'll take the torque with a bigger gear. I think. Lol
I need to do some testing
I don't think there's an answer.
Gonna depend on chain and raker depth. Resistance at rpm.
And torque moves the chain, but hp is torque at a given rpm.
SquareFile
1:49 PM
somewhere
Rpm out of the wood don't mean anything. Its what it holds in the cut. Bigger gearing is not always needs to be done with larger saws. But you have to know what your doing with a chain if so. Measure your sprockets and tach it in the cut. Here's the formula for sfpm/ surface footage per minute. Then you'll know which one has the highest chain speed.
[RPM X diameter of sprocket] x 3.1416 ÷ 12= sfpm
1:49 PM
There a builder on the AS that holds "RPM in the cut" to be his ultimate goal. His chains seem to spin and spin, but not cut that fast.
So I guess a torquier low rpm saw will pull the 10 pin with a high raker chain as fast the high rom saw with the smaller 8 pin and a low raker chain.
I see I've been a big help.
spencerpaving
1:49 PM
central new york
Hmmm big bar......could always machine a new flywheel out alum but twice the weight. ...kinda like a john deer b....guys out west race with big bars and the timing numbers aint alot diff from a good woods port
1:49 PM
Why does one run numerically higher transfers (physically lower and more blowdown) on saws with higher exhausts?
Does the exhaust not close fast enough to trap mix from a lower numerical transfer?
SquareFile
1:49 PM
somewhere
What does the "AS builder" have to do with this? Watch some race saw videos. They hold high rpm in the wood. Maybe cause that's there peak power.;)
jmssaws
Banneded
12:49 PM
Kevin's non-decomp is at 97, his is a beast too
My 660 runs great at 98 with good compression but it ain't even close to the 066 at 101,no rpm difference between the two. 066 is finger ported with less blow down though. Intake is 84 on the 660 and 78 on the 066
jmssaws
Banneded
12:49 PM
I'll finish this weekend.
What kind of compression do you think scott? I'm thinking 210 to 220, exhaust at 164 that's about all I'll get.
Definitive Dave
Piss Rev Mafia Member
1:49 PM
Central Ohio
hey if you want a velocity stack Jason , say the word and I will get it to you with a green meanie, squarefile built me some and they are purty
