Crzybowhntr
Apprentice Slacker
I am looking to make a chainsaw mill so I`d like to see some of the ways you have made them. Looking to make one that will take a 20"-32" bar. Any detailed pics would be much appreciated!
In the electrical section of hardware stores they sell this metal with holes in it ,you can bolt a mill together ,and use redi rod to adjust the thickness of the boards .
Grinding is not welding .lol at work the guys who do gorilla welds usually have a grinder in their hands
they are pulled from welding and grinding on stuff to be welded or cleaning off rustGrinding is not welding .
Was just teasin sir .they are pulled from welding and grinding on stuff to be welded or cleaning off rust
I was planning on making fancy measuring/lifting mechanism, but decided to keep it simple….OK I got lazy! I just loosen the two bolts drop the mill down on pre-measured blocks.
I put string between them so they don't get lost in all the sawdust.
